a little overboard or no?
I wouldn't spend the dough for a digital fused d-block. You can get them for much cheaper if you didn't go for the digital readout. But, if you want it, more power to ya.
i just think it would neat to have the read out, but i guess i dont NEED it. do u think the 30 feet of 0/1 awg is too much? o nce again its for power wire/big three/possible extra battery.
should i run the wire in a loom under my car, or just go for under the carpet?
If running it under your car, I'd opt for something thicker/stronger than simply loom. I ran 4ga under my buddies truck, and protected it with heater hose from Autozone and used those metal wire clamps to secure it to the frame. Thick, durable, heat resistant, etc etc. So far, it has been holding up wonderfully.
i know its safe......they have a rubber surround for something lol, but is it worth "rigging it" like that instead of making it run under the carpet.
thats the question is running it under the car rigging it or having a big *** lump line in your carpet from 1/0ga rigging it //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif not like you can hide it under the door step panels
you dont get a "big *** lump" under your carpet, you run it in a crevice or in a corner, not down the middle of the carpet //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
I would run it under the carpet, if that doesnt work out for you, you could do the under the car deal.
30ft is quite a bit. My battery --> trunk is about 17ft in a 99 4door accord. Of course if you are going to be doing big 3, and another battery in the trunk, 30 should be about right. You might have a couple feet left over, but better to pay once than have to order more again later.
saywhat?
satx120, jealous?
saywhat?
H'Burg Mississippi!
zachzchw
BP1Fanatic
    May 14, 2026
BP1Fanatic
    May 14, 2026
