A little help plz!
rokr_2007
Hey im new the forum ive got a question...
ive got a rockford P6002 i wanna hook a single sub up to that will go under the back seat of my 05 k2500 chevy double cab. got a premade box for it with an air space of .78 cu ft from car audio factory.
the sub i was lookin at is a Dayton Audio RSS315HO-44. i was told that for that sub to work with my amp i would have to run one channel to each voice coil...just wondering why i cant bridge the amp and run the voice coils in series??
if i have to run one channel to each coil for that sub id rather find a differnt sub and if thats the case anybody have a suggestion for a similar sub that i wont have to do that with?
Thanx in advance!
Welcome !
The sub is a dual 2 ohm, so wired in series would give a 4 ohm final load, you will have no problem running that amp bridge.
Welcome !
incorrect. the sub is dual 4 ohm. that is why he cannot wire the coils in parallel and operate the sub at 2 ohms bridged.
if i have to run one channel to each coil for that sub id rather find a different sub and if that's the case anybody have a suggestion for a similar sub that i wont have to do that with?
the simple alternative is just get a single coil 4 ohm sub and not a dual 4 ohm sub.
Dayton Audio RSS390HO-4 15" Reference HO Subwoofer 4 Ohm 295-469
agreed, but they don't make that model. so SVC it is.
---------- Post added at 04:56 PM ---------- Previous post was at 04:56 PM ----------
no worries, we look out for each other.
I appreciate bro !
rokr_2007
rokr_2007
Pierre SD
Sonic.
