A little hand with in line fuses
  • 4
Silerh7
I bought the soundqubed 4 gauge wiring kit and an audiopipe apmi 1300 amp to push two 10" type s. the problem is that audiopipe uses an inline fuse for this amp to power it instead of a fuse on the side of the amp. So I was wondering if I install the 100 amp fuse that came with the kit along with the kit and the 80 amp fuse that came with the amp, and it says it's required. I know audiopipe is talked down upon now, but I already have it due to every basshead and audiophile I know in Tennessee telling me they're worth it.
Just use the 80A fuse. That audiopoop amp is about as good as anything in its price range. Use it til it breaks then buy something better (more reliable) whenever you need to replace it.
heh //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
when it breaks, replace it with this
or better yet, this (kidding btw)
They should work. I have 6.5s in my lower door to replace the 8" subs that came with my mustang. They are fantastic, and outperform the 6 x 8s...
Well lets say I was running the tablet and 3 amps, would I use something more along the lines of a line output converter so that I would be able...
The correct answer is yes, you want both left and right so you get low end information from both channels. It is very common for recording...
Silerh7
Silerh7
Tennessee
youdoofus
    May 12, 2024
Brendon Jenness
    May 11, 2024
