A little confused need some help
J.D. Nichols
CarAudio.com Newbie
Ok I have a 1 ohm 8 inch Mtx right now that is being run by a 1000w amp that can run 400 watts x 1 bridged output at 4 ohms and 165 watts RMS x 2 at 4 ohms. 200 watts x 2 at 2 ohms. . And had 2 of the 1ohm Mtx running on two channels. So both had their own channel turns out that didn't work and like I said I'm only running one of the speakers and now that speaker just stops playing once and a while and the amp is not turning off and not going into protection mode. I'm worried that I while have to replaced that speaker already and till I can find a solution I've took the power cord out of the amp so the speaker is not running. I'm guessing that I will have to replace that speaker cause its just not meant for that amp so I've looking and I found the kicker comprt that runs at 1000w max, 500w rms and at 4 ohms. And I just can't figure out if that will work.
J.D. Nichols
CarAudio.com Newbie
J.D. Nichols
Ohio
J.D. Nichols
