a little advice needed
KyleBechtold
Quit reading this
the areas in red are about 5 inches wide 19 tall.. I am going to glass it.. what mat, resin etc should i use? how should i attach it to the box
You dont need fvckin 3" screws to attach a seal/beauty panel to your box. 3/4" screws would be more than enough, using 2 L shelf brackets per side would be plenty
I used these, there like 50cents to 2 bucks each depending on size
And yeah use plywood or mdf whatever you have kickin, who cares if your no good with a saw, I sure dont get my beauty panels a perfect seal first try everytime, who cares if it takes 10 cuts, just keep making adjustments til you get a tight fit.
Jigsaw would obviously be best, with carbboard template to get the initial shape.
Cheap easy and effective
well if you your dead set on glass i would mae a frame/structure out of dowel rods use like hot glue to put it together and stretch fleece over that and use hotglue to secure it and just add resin.
KyleBechtold
Quit reading this
KyleBechtold
Tampa, Florida
tylork92
NorthFramingham
    Jun 30, 2026
