a few questions before i wire my subs
tuff57
I'm wiring my 2 12 re se's in parallel. i have 3 questions before i wire them into my box tonight
1. if i take 2 wires and put them into one solderless connector will they both recieve power?
ex. 2 wires to send to each of the positive terminals
2. if i take the speaker wire and spilt it in two and use one side of the wire to go from the negative voicecoil to the other side negative voice coil will that work?
and finally
3. i have 2 positive terminals and 2 negative terminals off my amp (audioque 1200d) if i take speaker wire and put them both to the positive/negative terminal of my box will it be allright? the one wire from one positive and the other positive lead into the main box terminal basically same question as one just from running the wires from amp to the box
lol just run a wire from the amp posotive to both subwoofer posotives and the amp negative to the sub negative terminals... how they are attached, either daisy chained from the terminal, or amp, shouldnt make a difference
i have like a circle terminal that's the only thing thats confusing me on it, it has a cutout middle and then it has like a nut on the outter ring but it doesn't look like it holds anything down how does the wire stay in there?
tuff57
tuff57
long island, ny
tuff57
