a few electrical questions
NvrDoneD50
Young Gun
i need some advice as in what direction i need to go with upgrading the electrical system in my passport. im going to call tmrw and see if i can get an h.o alt for it but i have a few general questions that i need some help with.
heres a run down of what i plan on doing...
upgrading the alt to a h.o.
big 3 ground upgrades using 4ga
voltage meter in the dash
adding a second battery in the back..probly a kinetik 1400...if anyone can tell me if i need a diff size please do so and wheres the best priced place to get kinetik
2-0 runs from the front battery to the rear...one power and one ground
feed my amps with 4ga.... im going to run a ample audio exonic 3000.1 but im wiring it 4ohm so it will only be putting out 800 watts and ill have a 200w or so amp for my front stage
i think thats it so if anyone can tell me if running the 4ga big 3 grounds and the 0 for the batt might cause a prob let me know and if anything else dont look right point me in the right direction
thanks
Kinda confused.. just run the big 3 in 1/0 .. and why would you wire to 4 ohm.. if your only doing 800 @ 4 ohm you prbly dont even need another batt cuz thats not ******* much juice and HO alt should cover it
NvrDoneD50
Young Gun
NvrDoneD50
denham springs, louisiana
NvrDoneD50
