99 mustang passanger side tweeter removal
  • 2
pesky32822
orlando
i was in the parking lot with my friend and some one decided when they left that they where going to take the side mirror on passanger side of the car and i need to know how to remove the tweeter from the passanger side door it's the mach460 sound system any help whould be nice thanks
I replaced the entire mach 460 system in my mustang, and was able to mount the new tweeters in the existing enclosure. The part that is covered with the fabric will come off, it just takes a little patience. You can try pulling the entire thing off directly, or work a small flat blade screwdriver in around the edge and gently pry it. The unit is mounted to the door, only the fabric part will come off which will expose the tweeter. I hope this helps.
Could not tell you, but you may want to start by going to crutchfield and get a consensus on the 7 or so replacements they recommend. That average...
Might not even be an issue if you don't have any really big panels on it. Otherwise dowels or threaded rod across your wide panels would be the...
18
3K
I ordered the car with the upgraded B&O audio system....turn's out Ford bought the name but they didn't buy the quality. The system ****** to me...
Contact ANS he has a used Focal 8 Channel DSP that went for 1,300 bucks and is selling used I think shipped for 450. And from what I have seen and...
13
This will be an interesting issue to find out. Subscribed!! Are you running components? Ive had some caps blow in Passive xovers and a little...
991
pesky32822
pesky32822
orlando
mustangfan
Doxquzme
    Jun 15, 2024
Doxquzme
    Jun 15, 2024
