97 Tiburon build
  • 5
I am going to start out with some equipment that i have from other builds and slowly add to and replace out with better equipment HU Kenwood KVT-516, Interiors (Temporary) 2 sets of ARC audio FD6000 6 1/2 on Mmats sq 4100 4x100@4 ohms, 1 MTX t9512-44 on GTO1201.1 II 1114x1 @2ohms RMS, 2 10w0-4 on sq4100 4x100 @4 ohms (temp later for interiors) Stinger HPM 1/0ga Blue Big 3, 1
run of 1/0ga in process of upgrading my alternator/ dual alternator setup (still deciding on this) and still deciding on xspower d3100 2-3
Im assuming that they used the same case for your alt as mine, there was a lot of **** that had to be done for that but its worth it, Btw, how does your alt do with the cold, mine doesnt charge till it gets warmed up a bit.
Seems ok but haven't really driven it that much only running jbl 1200.1 right now on 15in 9500
Had to do a lot of grinding on alternator and took off tensioner completely also had to grind little chunk of metal down on engine and get 1/2 longer belt seems ok so far
Sq4100 started smoking:'( , have to get either sq4100 or crossfire 804 fixed deciding on which one. Oh well gonna throw something else in there for now so I have something besides just bass 15 hitting decent though.
Put old school mtx blue thunder pro 150x2 for now on fd6000 sounding decent needs eq work , but nothing like sq4100. Need to put tsunami battery terminals in to cleanup under hood
put on tsunami battery terminals under hood wish i didn't now gonna have to buy some new terminals so i can double up big 3 and do another run of 0 to the back. Also cant wait for tax money so i can get my Xs batteries d4300 under hood, and 2 d3100s for back.
16
I got to message a DD woofer builder a decent bit my last stent of box designing; they would send me designs to do for or with individual...
Currently Audison amps 500.1 and 4.300 with kappa 90csx 6x9 component set. Pair of morel 6.5 rear and a single 10” alpine type R.
rsnookie69
rsnookie69
chicago, IL
VisceralSound
Decebal
    Jun 10, 2024
