96 integra.. electrical problems?
hdj20
F*CK SONY
First off heres the story got a car yesterday, drove it around fine first day started it probly 3 times. car started again today. then couldnt get it when i got home and went to go start it again. wouldnt start got it jumped 3 different times through out the day took it to autozone said it was a bad battery. so i got a new one car started up good, got home tried to start as soon as i shut it off and once again wont start. their are 3 wires into the positive on the battery and one on the negative. i know it has an alarm and a deck. i have no clue what it could be. please help!
the 3 wires on the positive are probably starter, alt, accessory box. was the battery tested and declared bad? or was it just assumed so you'd buy a new one? if it's the first than you probably have a bad alt as well. if it's the latter than my guess is that you have a 12v constant hooked up that where it should be a 12v ignition switch.
i dont have a system right now just a cheap deck i jus got the car they did a horrible job on the deck install. nd yeh the battery was declared bad accordin to them and their tester
hdj20
F*CK SONY
hdj20
wisconsin
hdj20
