96 Blazer-- 2 18's budget build
Under the hood:
Subs have broken in a bit. To my ear seems to be around 150dB. Stock alternator is keeping the voltage sufficiently high. Stays above 13v.
After 4 coats:
Box turned out amazing. Tomorrow the equipment will be re-installed. One of the four ports is also temporarily plugged (from the inside). Using a towel to test this idea out, the sub lower frequency response was increased while the higher bass (about 45 Hz and up) still was well pronounced. On paper, plugging one port lowers the resonant frequency of the box about 5 Hz. Port performance has not been lost even with two ports plugged; the large 1.5" flares on the ports help out a lot.
Some of the paint ended up coming off. With really high humidity and time constraints we had to paint without giving ample time to let the primer dry.
Bass knob, volt meter, and some switches:
Rear wiring:
Very happy with the overall look of the system. Turned out better than I had imagined.
Put together a small video. Didn't get much footage though.
Subs seem to have more mechanical and thermal potential. Without clipping the amps the subs barely warm up, and when not playing anything under 30Hz they only exert about an inch. Perhaps a future upgrade will be to swap out these amps for two 3500's.
778
A pair of American Bass Hawk 15s will slamm home as well. Just put in a pair in a good friends 02 T.Car in 7.0@31htz on a Cresendo Skyway 3k...
29
Oh come on! Why'd you have to go and tell me the price? Now I'ma start eyeballing them.
you did. https://www.caraudio.com/threads/double-din-cd-player-with-screen-mirroring-a-link-android-auto-budget.614240/#post-8864499 OP:
PSturmer
PSturmer
Minnesota
PSturmer
    May 19, 2024
    May 19, 2024
