SOLD 8" Flared Ports FS
amartin_72
Banned
1,828
Madison , WI
7.75" inside dia.
1/4" wall thickness
8.25" outside dia.
11.25" Outside Dia.
10" cutout dia.
8 mounting holes
47 in ^2 port area good for 2.9 (16in/ft) to 5.2 (9in/ft) cubes per port- Depending on how much port area you want.
Each flared end piece is 6.5" effective port length - $15 ea. 2 usually required
I have 8" pipe if you need more than 13" port length - $1 per inch
Plus actual shipping
Having a flared port equipped enclosure makes it possible to change the tuning and port area of your enclosure to have drastic impact on your subs excursion, thermal and mechanical power handling, spl and sq
The late 80's early 90's car's OEM speakers were of the same quality as today's offerings. The main difference was the rear speakers were enclosed...
10
You're not trying to figure out the mass of air in your 3" port or whatever, you're trying to figure out the mass of air that you would need in an...
Are you going to do actual aeroports with flares on both ends? I’m running a single 4 inch aeroport on my little 750 watt 12. It has flares on...
The black rca out is your mono sub output. That is the one you would use for signal to your sub amp.
And you failed to mention airspace of the box or the sub and power you were running. In 89 most subs were extremely low xmax meaning very little...
14
amartin_72
Banned
amartin_72
Madison , WI
dohckiller808
    May 31, 2024
    May 24, 2024
