Sold 8" Flared Ports FS
amartin_72
Banned
7.75" inside dia.
1/4" wall thickness
8.25" outside dia.
11.25" Outside Dia.
10" cutout dia.
8 mounting holes
47 in ^2 port area good for 2.9 (16in/ft) to 5.2 (9in/ft) cubes per port- Depending on how much port area you want.
Each flared end piece is 6.5" effective port length - $15 ea. 2 usually required
I have 8" pipe if you need more than 13" port length - $1 per inch
Plus actual shipping
Having a flared port equipped enclosure makes it possible to change the tuning and port area of your enclosure to have drastic impact on your subs excursion, thermal and mechanical power handling, spl and sq
So you were the guy walking around with the big aero at the Kenosha show? I had the orange ranger with the blowthrough. Those ports you had looked legit.
Just did an Install tonight with one of these ports and the Type-r 15 loved the port it was loud and I went to check out how much it was moving and it was only about an inch on an AudioPipe 1500d but it sounds good too. Pics soon.
Wot for your 4 15's 3 or 4 Ports would work well. They would probably be about 17" long each so $34 each plus shipping.
Correct but I use aluminum duct tape or regular duct tape and its strong enough. I have a box with an unsupported 20" long port with the aluminum duct tape and its held together for 6 months. If you brace the other end of the port it wont come apart for sure.
amartin_72
Banned
amartin_72
Madison , WI
dohckiller808
