It says he got them in the doors and rear deck I thinkIn his Sig he states Rear Deck. Unless Im reading it wrong? I do have visual issues at times. lol
Dude loves his 6x9s,It says he got them in the doors and rear deck I think
Thank you for the recommendations!Audiofrog GS690
Morels
It will be trial and error.
My vote is CDT, after you measure the available depth.
You could lose midrange with a stouter 6x9. Not sure if you want to go 3-way or widebander. That is something to consider as you move toward a speaker with a better lower response.
ImageDynamicsUSA XS69
XS69 Component System XS Series Convertible 6x9" Component System with 28mm Tweeter INFO ABOUT CXS SERIESimagedynamicsusa.netGS690 6" x 9" PREMIUM GRADE AUTOMOTIVE WOOFER/MIDRANGE LOUDSPEAKER - Audiofrog
Previous Next OVERVIEW FEATURES TECHNICAL DETAILS DOWNLOADS OVERVIEW Designed to be used in two- or three-way systems, the GS690 includes a non-resonant injection-molded ABS plastic and fiberglass vented basket. For […]www.audiofrog.comTEMPO ULTRA 2-WAY Car Audio Performance - Morel Hifi
TEMPO ULTRA 2-WAY 350176 The Tempo Ultra features both 2-way and point source solutions for tho Morel Hifiwww.morelhifi.comCDT Audio HD-690CF
www.cdtaudio.comCDT Audio ES-0690 GOLD
www.cdtaudio.comCDT Audio CL-69SUB CF
www.cdtaudio.com
The 6x9 speaker size doesn't get enough attention. I've run the Kappa 900 and 90csx, and I'd recommend making an adapter for an 8".
TM8 – StereoIntegrity.com
stereointegrity.com
I love 6x9s as well. id run them if I didnt have to wack up my doors or place Pods. But more choices in the 6.50 speaker range. CDT HD series are nice, and other raw speakers to build your own set up that will get down. It takes a few to keep up with a 4k on up sub stage.You have to get creative usually and pick and choose drivers and locations for a nice mix. EQ comes in handy for sureYes. They move a lot of air and 8"s don't fit in either location.
If you want to move more air, then you might want to look at 6x9 "subs" and going 3 way up front. Either way, I think if you want to move more air the answer isn't swapping drivers, it's fabrication.Thank you for the recommendations!
With the speaker brackets I have the mounting depth is 4.7", so there is plenty of room in the doors.
I should probably mention that I listen to almost all metal, so midbass is very important to me.
What do you mean by fabrication?If you want to move more air, then you might want to look at 6x9 "subs" and going 3 way up front. Either way, I think if you want to move more air the answer isn't swapping drivers, it's fabrication.
Either fabricate a way to jam an 8-10" driver in the door or get a 6x9 "sub" and fabricate a place for a midrange driver and go 3-way up front.What do you mean by fabrication?
Fabricate what?
CDT make some excellent speakers. Ive enjoyed mine. Cant wait to get them back in. Im about getting tired of my temp. set up at times. But it still sounds fairly decent atm. I really like Polk MM series components and Infinity Kappa series as well.I have my CDT 6x9s on a bandpass crossover. 65 HZ high pass and 250 HZ low pass. I use linkwitz-riley filters at 24 DB slope.
