6x9 slope
Audiofrog GS690
Morels
It will be trial and error.
My vote is CDT, after you measure the available depth.
You could lose midrange with a stouter 6x9. Not sure if you want to go 3-way or widebander. That is something to consider as you move toward a speaker with a better lower response.
The 6x9 speaker size doesn't get enough attention. I've run the Kappa 900 and 90csx, and I'd recommend making an adapter for an 8".
Audiofrog GS690
Morels
Thank you for the recommendations!
With the speaker brackets I have the mounting depth is 4.7", so there is plenty of room in the doors.
I should probably mention that I listen to almost all metal, so midbass is very important to me.
Yes. They move a lot of air and 8"s don't fit in either location.
I love 6x9s as well. id run them if I didnt have to wack up my doors or place Pods. But more choices in the 6.50 speaker range. CDT HD series are nice, and other raw speakers to build your own set up that will get down. It takes a few to keep up with a 4k on up sub stage.You have to get creative usually and pick and choose drivers and locations for a nice mix. EQ comes in handy for sure
See if you can wedge these in your doors...they'll move air
If you want to move more air, then you might want to look at 6x9 "subs" and going 3 way up front. Either way, I think if you want to move more air the answer isn't swapping drivers, it's fabrication.
I have my CDT 6x9s on a bandpass crossover. 65 HZ high pass and 250 HZ low pass. I use linkwitz-riley filters at 24 DB slope.
CDT make some excellent speakers. Ive enjoyed mine. Cant wait to get them back in. Im about getting tired of my temp. set up at times. But it still sounds fairly decent atm. I really like Polk MM series components and Infinity Kappa series as well.
I have an extra pair of these, NIB, $100 shipped!
14
Excellent!! Looks to be in tact. It will be a workhorse for you man
40
4K
This is still a very nice Deal package for an entry level amp set up for some quality amps for the money...
18
If the JLs are not entry level, then do not torture yourself, just go for it. You already enjoyed those DS18s. In case you do not like them, the...
I have heard plenty of headunit only setups that sound pretty good. JVC radios have very good sound, so the issue may be the wiring, or the back...
14
ender2664
ender2664
California
    May 10, 2024
3toneEYZ
    May 10, 2024
