6th order design needed!!!!
norrizzle90
Cant lose with 22's
hey guys, i need a design and cutout sheet for a 6th order. i will be running 4 15" american bass xfls off of 3k. will be going into a 2004 avalanche. my max dims are 49w, 22.5h, 40L (cant go more than 40, i need some of my bed). lmk guys i really need help.
about 25.5 cubes without displacement of subs or wood, for 4 15's and a 6th, little small, i would do a 4th, share rear sealed on 2 subs on each side, then fire all 4 into ported chamber, 1.75 sealed per sub, 3.5 ported each - tune to 45hz
That'd be a low, loud box right there.
that box is at least 2+ sheets of wood, some 2x2's, bunch of tightbond and couple tubes of silicone (yes silicone, liquid nails *****, and smells bad too), because it is going in the bed of a truck, painting a coat of resin or bed liner on outside is almost a must and does not hurt in sealing the pourous mdf.
I would build it so port was removable to load subs and abitilty to change tunning if needed. 250sq" of port,
that box is at least 2+ sheets of wood, some 2x2's, bunch of tightbond and couple tubes of silicone (yes silicone, liquid nails *****, and smells bad too), because it is going in the bed of a truck, painting a coat of resin or bed liner on outside is almost a must and does not hurt in sealing the pourous mdf.I would build it so port was removable to load subs and abitilty to change tunning if needed. 250sq" of port,
This
norrizzle90
Cant lose with 22's
norrizzle90
detroit, MI
97maxima
