600 rms needed
I have a Soundstream VGA 800.2 Van Gogh that is Class AB but runs cool. Besides, Class D amps aren't as efficient in the upper volume levels as most people think. Ask most any tech. They drink as much power as Class AB amps when you turn up the volume.
2 X 200 RMS 4 Ohm
2 X 400 RMS 2 Ohm
1 X 800 RMS 4 Ohm Mono
RUBI™ (Rapid-Use Branched Impulse) Proprietary power supply topology
STACT™ (STabilized Apex Current Topology) Reduces power supply stress by 50%
Trident™ Amplifier protection topology
Ultra Low ESR Capacitance bank ensures rapid power delivery for dynamic peaks
Continuously variable 12dB low-pass crossover (30Hz to 4kHz)
IDI™ (Intelligent Distress Indicator) gives visual amplifier protection status
Triple Darlington OUtput Circuitry
Continuously variable high and low pass crossovers with 12 dB / Octave slope (30-4KHz)
Vortex induction fan for thermal management
Platinum RCA Line inputs and outputs
Platinum 4 gauge power inputs
Rail stabilization protection circuitry
Tri-mode operation
BIP™ Bias Input Protection
Harmonic Bass Alignment™ Produces tighter, more accurate bass reproduction
Bi-Linear selectable 2 way crossovers for amplifiers and line outs
10Hz - 50 KHz Frequency response
>115dB S/N ratio
>500 Damping
.15V - 12.0V Input sensitivity
0.02% THD
Dimensions Dimensions 15.8" L X 2.6" H X 11.2"W
How much to 55406?
2 X 200 RMS 4 Ohm
2 X 400 RMS 2 Ohm
Tri-mode operation
>115dB S/N ratio
>500 Damping
0.02% THD
BrownVanMan
BrownVanMan
Minneapolis MN
BassAddictJ
