6 6.5 subs, what do you think?
david in german
http://img.photobucket.com/albums/v623/david_in_germany/P1010431.jpg
//content.invisioncic.com/y282845/emoticons/naughty.gif.94359f346c0f1259df8038d60b41863e.gif :naughty: //content.invisioncic.com/y282845/emoticons/naughty.gif.94359f346c0f1259df8038d60b41863e.gif :naughty: //content.invisioncic.com/y282845/emoticons/naughty.gif.94359f346c0f1259df8038d60b41863e.gif :naughty: //content.invisioncic.com/y282845/emoticons/naughty.gif.94359f346c0f1259df8038d60b41863e.gif
I will be powering it with a Tsunami db1100 when it arives
One problem I had was the speakers have 14 guage push terminals and they are dual voice coil (2ohm coils) so I had to wire it with separate wires and built a special distro block for it.
Harness installed
http://img.photobucket.com/albums/v623/david_in_germany/P1010428.jpg
http://img.photobucket.com/albums/v623/david_in_germany/P1010429.jpg
http://img.photobucket.com/albums/v623/david_in_germany/P1010430.jpg
I tested it with about 100w and it is loud!!!
elemental designs EU-700's wang!!!
Here are the specs on the subs if anyone is interested. Not listed is the 14mm XMAX //content.invisioncic.com/y282845/emoticons/yumyum.gif.0556df42231b304b9c995aefd13928a8.gif
http://edesignaudio.com/product.php?cid=15&pid=32&tab=Specs&cur=USD
The enclosure is 1.5f3^ and sealed. I was looking for a smooth response and good shock and awe, I think I got it //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Here are the specs on the subs if anyone is interested. Not listed is the 14mm XMAX //content.invisioncic.com/y282845/emoticons/yumyum.gif.0556df42231b304b9c995aefd13928a8.gifhttp://edesignaudio.com/product.php?cid=15&pid=32&tab=Specs&cur=USD
Also I have less that $215 in the entire thing
u should have put them in a 4th order bandpass tuned to 45hz..then u will have awe factor
80
The point of me staying sealed was space. The bandpass would have been about 2x the size and I do have a family so that was out of the question. Also they will be firing through a ski hole in my rear seat. I will post on how it sounds soon //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
how full of a sound will you get from just the 6.5s? wouldnt it be more like midbass?
Yes, if you are using a speaker designed as a mid bass. The EU-700 was designed as a sub woofer and not a mid bass though.//content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
14mm P2P maybe //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Ben: What is the travle on thoes speakers i used mommy and daddy's money to have you design me?
Engineer: 7mm one way
Ben: Well, i have an idea, best marketing strategy eveah! Ill not advertise the Xmax and then have my henchmen start rumors of 14mm Xmax and everyone will think it is one way!!! Im a genious. That idea is almost as good as "loosing" thoes amps.
ok /eDuh bash
it will be a decent system, and something not everyone has. Dont expect the low lows to be uber amazing. You simply dont have displacement //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
PS
WTF! why did you use P-Board?
80
i got two of them in a nolte audio ds and i pulled a 129 thought it was pretty impressive but id like to try that idea of the 4th order bandpass but i hvae no clue how to build one or how big it would actually end up being?
david in german
david in german
mannheim Germany
OlogyAudio
