Jared530
Drop bombs
Hi, i was planning on selling my type-R's i just got and buying 2 12" Goliaths. I was wondering if anyone has ever heard these subs hit or know anything about them. Heres the specs, tell me if i should perchase these subs or if i should go with somethine else, i have a pretty big budget.
12" Goliath series subwoofer
6,400 watts peak output
3,200 watts RMS output
Integrated One-Piece Spider- Tinsel Lead Design
Chrome Cast-Aluminum Speaker Frame
1.4" Extra-Wide Polyester Surround
360ý Vented Voice-Coil Assembly
Back-Plate Bumped for Long Excursions
Nickel Plated Push & Insert Terminals
Metal Dust Caps Prevent Hi-SPL Cave-In
Dual-Layer Conex Spider- Assembly
Fs = 39.63Hz
Qts = 0.37
Vas = 17 Liters
Xmax = 25mm
SPL = 98.29 dB @ 2.83v
Quad 2-Ohm Voice-Coils
Can be run @ 1/2-Ohm, 1-Ohm, 2-Ohm, 4-Ohm, or 8-Ohm
18-3/4lb./300oz. Triple-Stack Magnet Assembly
4-inch Bi-Flair Black Aluminum Voice-Coils
High-Strength Composite Silver & Fiber Glass Cone
Fs = 39.63Hz
Qts = 0.37
Vas = 17 Liters
Xmax = 25mm
