6.5" installation question? Please help
  • 4
Carnivorous18
T3h G33k
I got a set of ID ctx65cs. The plastic door panels on my civic are supposed to fit 6.5" mids, but the basket is just barely too wide.
Do I need to cut the panels so its open to the outer edges of the speaker?
Also can I bolt the speaker directly to the metal of the door with self tapping screws, or does it need something in between the door and the speaker?
Last but not least, does the speaker need to sit flush on the metal of the door? I wana finish this today all help is appreciated
some pictures would help me give you a better answer. but you could use some mounting rings to make the speakers sit flush and seal them off. or if it would be easier to do, just trim the door panels so that they can fit inside.
If you don't care about putting your stock speakers back in this will work.
Yes. An alternative is to buy or make an adapter spacer that lets you install these speakers without any cutting of the sheet metal. You will still have to modify the door panel for extra clearance based on what you said.
Not necessarily. You need to have an airtight fit but the speaker does not need to be sitting flush on the metal. If there is another material sandwiched between the speaker and door, like the aforementioned adapter plate, that would suffice. I have seen non-hardening modeling clay used to fill a gap but I have not personally tried it. It wouldn't hurt to try it but it's not ideal.
Twist both grounds together. Good call on checking power with a multimeter. I assume you have pulled out and re-inserted the fuses, so as a quick...
Hi, I have a 2015 Mercedes W205 with the standard audio 20 system, which is terrible to be honest. In my W204 it was really good even though I...
Generally you can still use the High Level inputs on most any amplifier to get it installed off the HU speaker wiring. Its a bit old school way of...
10
Carnivorous18
T3h G33k
Carnivorous18
San Diego, CA
Louisiana_CRX
    May 12, 2024
Brendon Jenness
    May 11, 2024
