6.5 comps on 75w rms
VIP3R
what do you guys recommend?
ive been doing my research..
only have 75w rms to work with atm as well.
been looking around...but it seems everyone goes over the RMS anyway..
ive been looking at the pioneer ts-d720c, and id ctx65cs and a few others....
even kicker and the phoenix gold...
i have 6x8s atm and want to upgrade... my current 6x8 get loud
do any of these get loud as well?
thanks
any recommendations other than those?
how are the kicker 650.2 (not so great id imagine?) they handle 75w rms though
or do the pioneer ts-d720c get loud?
6-1/2" 2-way Component System (Marine Certified)
Power Handling:
Peak: 600 watts per set / 300 watts each side
RMS: 200 watts per set / 100 watts each side
Aerated Polypropylene Cone
Removable Phase Plug
Butyl Rubber Surround
Neodymium Magnet Structure
Die Cast Aluminum Basket
U.S. & Euro hole patterns to line up with the mounting screw holes of virtually any vehicle
1 1/2” Voice Coil
Polyimide Voice Coil Former for high thermal stability
4-Way Gold Plated Input Terminals Corrosion resistant terminals
Vent Holes in the basket equalize air pressure on both sides of the spider for more linear travel, flatter frequency response and lower distortion
1" Ring Radiator Tweeter
Neodymium Motor Structure with Faraday Cap
High Frequency Waveguide Prevents phase cancellations for smooth, uniform frequency response and wide dispersion
Zoebel Crossover Network flattens the system impedance curve for more efficient power transfer and flatter response
Air Core Inductors with Oxygen Free Copper wire, for wider dynamic range, contrast and punch
Mylar Capacitors
Tweeter Protection Circuit
Gold-plated connectors
Cast-Aluminum heat sink
2nd Order Low Pass Filter
3rd Order High Pass Filter
Frequency Response: 40 - 23,000 Hz
Sensitivity: 92 dB
4 ohm Impedance
polk db pretty **** nice for a mainstream brand //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
not my favorite but not on my no list by any means lolz
thats why i started selling polk
then there are these: DLS classics //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif bad *** SQ speakers from scandinavia
Woofer size 16,5 cm / 6,5"
Power handling capacity 50 W RMS / 80 W max
Tweeter 16 mm / 0,63"
Frequency range 50-18.000 Hz
Crossover point (Hz) 6000 Hz
Sensitivity 91 dB (1W/1m)
Outer diameter of woofer 165 mm / 6,5"
Magnet size 80 mm / 3,15"
Crossover Cable filter with 12/12 dB slope (LP/HP)
Mounting depth 63 mm / 2,48"
Mounting hole 146 mm / 5,75"
Impedance 4 ohm
notice they have hand made pulp speaker cones?
best sq there is ... paper //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
im just looking for better performance than my 6x8s without paying a fortune and using the 75 w rms i have for now...
thats all
VIP3R
VIP3R
Tempe, AZ
ricktcole
