5 passenger car w/ a WALL!?
JEXTEL
Well i was going to purchase an old 1st gen blazer for my basshead needs but i thinking just going to tear apart my maxima and cram everything in there..
I want to cut out the rear deck and build a box that will go along the rear windshield and be place in such a way that the rear bottom seat is still in the car so can still seat 5 ppl..not that i have that many ppl in my car i just like the fact that i can do that if i want too..Here's are some drawing of what i mean..ill prolly do this mid summer or the very end of it..
The goodies i plan on using are: (yes im on a SMALL budget)
2 ma audio hk802sx's
jbl 75.4gto(after i get it fixed)
other amp for highs ?
2 runs of knu 0 gauge with 2 runs of 0 gauge welded to the frame
ill keep my front stage and add 4 Eminence 6.5's and 4 eminence super teeter(all these will have seprate boxes on the wall)
Box should be about 9.5cu ft NET
4 everstart MAXX marine deep cycle batteries(maybe later i can afford 3 HC2400's)
1 HC2000 up front
alot of SMD(sound mat destroyer)
and a Iraggi 220amp alternator
Also what do i do far as suspenison because im estmating it will be somewhere around 800lbs???? I going to throw some kyb gr's with maxspeed lowering (fr 1.5" rr 1.3"") springs maybe i should just lower the front and put of the stock springs in the rear?
why would you put tweeters or midbass drivers back there?
you're most likely going to get flamed to hell, but i would probably redo the box idea if i were you, and i highly doubt you'd fit that box and 3 passangers in the back
dumb idea, the back seats would not be functional unless your passengers were sitting against your speakers. do yourself a favor and either buy a vehicle that would wall off more easily or think of something different for this car.
We're basically telling you it isn't going to work.
Highs on a wall would most likely sound terrible, as they are VERY directional drivers.
Mixing 10's with 12's is a no.
Walling off the back of a car while retaining the rear seats = not gonna happen.
Well you're SOL because its one or the other.
You don't deserve to do audio in the back with 12s 10s and 6.5s planned in a single spot. Keep the back seat
the 10's are for highs!
JEXTEL
JEXTEL
Bridgeton, NJ
mazzasec
