5 passenger car w/ a WALL!?
If you're gonna do a wall. DO A WALL! //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
[/img]
this isnt a wall //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
You sir are very perceptive. //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
**** it will be that weak? 220amp alt 2 runs of knu 0 gauge and 3 batteries? hmm and tell me more about the 4th order bandpass through the deck..
^^^^I was suggesting a few options as he seems to be open for suggestions.
what an a$$hole..i did measure
You measured eh? don't lie.
and my parents did buy my car i bought it, and im not 17 either dumb a$$..
Stop lying and if you are not 17 fix your profile.
also far as making a box and getting to fit it WONT but if you had any sense you would build the box in the car itself!
Listen you ****ing newb.. no wait.. you ****ing bewb..
It wouldn't matter if you assembled the box inside the car.
Because of the dimensions of the rear seat area of your car it would not matter! you would have to completely get rid of the back seat and have a wall almost directly behind the front seats.
Your drawing is NOT realistic at all! shows you did not measure at all you just ****ing made it up in yer head and spit it out.
And you would have rip out the rear interior and possibly modify parts that could not be replaced easily. You also mention expanding foam between the box and the rear window.. You would most likely destroy the car and any possible resale value.
everyone is so tuff on the net but wont say nuttin to me in person..
Hah.. Yah it's true in person I wouldn't even bother i'd just point and laugh at you.
Wow.... 12's, 10's, 6.5's, and tweeters all in one place. //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
I guess its better than 4 W7 10's and a W7 13 all in the same box.... LOL.
Oh and OP, your idea sucks. You can have passengers, loudness, or a simple design... You can only have two of those choices.
If you want loud and simple, you can't have passengers.
If you want loud with passengers, its gonna be crazy hard to build.
If you want passengers with a simple box, it won't be all that loud.
6th order Iso-bandpass ported through the rear deck. Clean entry into the cabin, sounded really good.
[/img]
i like that.. one but i heard the 4th ad 6th order bandpasses are a hit and miss thing if you do it well your golden but if you do it wrong it will ****.. whats easier to do? the 4th or 6th? and do they get pretty low?
yes im open for suggestions..
I like the 6th order better. Front and rear chamber tuned differently. Mine got really low and loud. If you are just shooting in the dark results will probrably not be good, if you design properly it will surprise a lot. I have always got good results with bandpass designs.
How many chambers is that box and how many ports
Dose not look like 6th order
Looks like dual 4th order compound iso
The port area is too small
I have a maxima. I built the biggest box I could in my trunk. It came out to be 7 cubes net after all displacements, and had 190 in^2 of port and was tuned to 34 hz. (built IN the trunk.)
If you do rip out the rear deck and build up to make it a wall behind your passenger seats, you can probably get 10 cubes or so after all displacements.
But then you are not going to have ANY room for your batts and amps in the trunk.
If you do that, just move your front stage to the front of the car. Leave the wall just for the subs. Put 8" drivers in the doors for 60hz up to wherever blends well with your 6.5 inch comp set, and do kick pods with the 6.5 inch comp set in them.
Thats what I would do if I were you and set on a wall behind my back seat anyways.
JEXTEL
JEXTEL
Bridgeton, NJ
mazzasec
