SlickCMRick
coming along nice //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
lol, ya I sanded for 3 hours so my arms were a lil tired and this was after loftong for 1 hour so i had the shakes, plus my camera takes poop shots at night. When the weekend comes I should be all done //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gifcool man.. can't wait to see the final product.. keep us updated.. and dammit hold the camera still when ur taking a picture!! lol jk.. but better quality pictures would be a PLUSSS..
Have some patience and let what you have dry really good.With a finsh DA sander, (I hope you have one), and some 1500 grit paper, wet sand it till there is no shine left anywhere. Then do it with 2000 grit. Then buff it back to a shine with a buffing compond and polisher.
If you do not have a finsih DA sander, you might be able to do it by hand. But you have to be really careful not to dog too deep.
Get some 1500 and 200 grit paper, wrap it around a sanding block. Do not use your bare hand. I use Dura-Blocks myself.
Wet sand like above. Not to much pressure so you don't dig in.
Keep with the pics and lean against something to stabalize your sway.//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
That is some dang good info! Thanks a bunch, I'm going to pick up a sander from walmart tonight and some 1500 grit and 2000 grit and do exactly what you said. You think walmart will have a decent one? Or should I go to home depot the largest hardware store around where I live?Here is a pic of the finish DA sander I like to use.........![]()
And check out this site for the Dura-Blocks and a vid on using them.........
http://www.innate.com/Tools/DuraBlock/dura_block.htm
Put it in the sun as long as you can to get the best cure out of it.I will let the box dry tonight and till noon on satrday then start the sanding process.
Do you need to buy specific wetsand 1500/2000 grit sand paper for those powered sanders? Or can I use the standard 3M 8 1/2 x 11 sheets?
Also how much water should I use during the wetsand process maybee just get the paper wet with a sponge in my hand or are we talking a continual stream?
It will work. Use the highest speed at first, then drop it down. You don't want to burn through the paint. That will piss you off real fast.I only have and orbital buffer not a rotary buffer with variable speeds. Will I still be able to buff it back to a shine with this orbital buffer? Should I buy a cheap rotary buffer too when I'm there?
Do you have any links of what type of polishing and buffing compound to use?
Thanks!
