sand with the 230-320 and then with a 400grit. it makes a world of diffrence. i had to paint my pods twice because you could still see the scrashes from the 320 grit paper.
when you sand with the 400grit it should look gloosy. like if youre polishing the part more then sanding. if you want an even better look then sand with 600grit. as your final sanding before the painting. that will realy bring a shine to it.
here is the
link scroll all the way down.
laters
PS: that enclosure is looking hella good.
I was looking at the pics of the box in the vehicle and it looks like the clearance you have between the trunk and the box. is not = or > then the port width. so if i was you i would find a way to fix that, if not the enclosure its not going to perform to its designed potential. it will still sound ok, just not as good as it should.
just my two cents.
later
Thanks for the usefull info and input on my project. I will take your advice on
what type of sand paper to use before I paint. After I get all the paint on there
tonight, tommorow I will will spray some clear on it and wetsand it to a mirror like
finish then do a nice buff on it with some mequires 1500 grit polish. The final
project I'm hoping should be like looking into a black mirror //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
I've also notice that my clearance is pretty short between the rear hatch and the
air port, but I only had the box placed like that in the pics on page 1 for viewing
purposes only. I'm actually gonna have my box facing forwards which will give
me more then adequate space between the rear seats and the air port, plus I
can fold the seats down if I wish. I know, I know "you lose some output" is what
everyone says, but in 2dr blazer like mine I actaully think it sounds much better
from the inside and ouside of the car after doing extensisve testing....
I've got about 200sq. ft. of dynamat xtreme installed on the rear hatch, rear sides
and roof and with the subs facing forwards I get absolutly no rattels from the
outside of the vehicle which I think is freaking sweet //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif The only thing that
makes some noise is the rear hatch window, but Im working on a fix for that.
