5 channel?
  • 4
caterham09
Olympia
Im doing a new build in my new car and i had a question. I saved both amps from my old car but decided that i wanted a different 4 channel with more power. My question is would i be better off buying a 5 channel and running both the speakers and subs off it or using my current sub amp and just buying a new 4 channel
Depends your goals. If space is limited five channels are awesome. If space isn't limited why pay way more for a five channel when you can get more power for your money using a 4 channel and a bass amp.
So is there any 4 channel you could recommend that does 4 x100 for under $200
It's not under 200, but close. Q4-120
Also look at mb quartz, ppi amps, CT sounds. I have the soundqubed 120.4 and I really like it. If you buy used your money will go mu ch farther
ppi ion 520.4 for 120$, ppi bk 800.4, Precision Power PPI P900.4 for around 200$ which gets your 145 watts x4 at 4 ohms or 225 watts x 4 at 2 ohms. Both amps are very proven to do rated cleanly and have clean sound.
10
508
Slapz are sfb clones from my understanding. What I was pointing out is how much info slapz gives about their amps 😂
35
Thanks for that. Good point about the chimes, I 'll have to check. My thoughts were that a true center channel could serve to raise the sound...
266
It is Opel (Vauxhall) Astra J 2011 model, I change the HU to Kirinavi 10 inch screen. The factory speakers are Infinity and would have come with a...
690
caterham09
caterham09
Olympia
caterham09
    May 12, 2024
Brendon Jenness
    May 11, 2024
