4th order help
There are a couple on here that will help, but will charge. It sounds like you are trying to figure out a design for someone else? 80 inches did a 4th order for me using some very cheap close out woofers. A lot of people were surprised when they listened to them and then heard how much money I actually put out on the set up. I think both woofers cost me 40 bucks from credence.
This is what I know:
  • Sealed chamber determines power handling, somewhat response.
  • Ported chamber determines efficiency, also has to do with how steep the cutoffs are.
  • Bigger the port, the better, to an extent. Anywhere up to around 30in^ of port per cubic foot of ported airspace works great for SPL and setups where you are looking for good numbers. Less control of cone.
  • Smaller the port, the more gradual the roll off points, but with less efficiency.
  • Basically I try for a roughly sized sealed chamber, and then build the ported chamber as big as possible usually. Can be different based on the subs or the desired sound, but Ive done some pretty crazy ratios, like 1:4-1:5 and they always sounded great with a nice peak right where I wanted it.
Its all give and take. Each part does its own thing, but is affected by the others. It really is more than the sum of its parts. They are pretty easy to design and get to sound good. As long as the ported chamber is in the ballpark area of what it needs to be, the sealed chamber makes it hard to mess up too bad.
Pretty helpful info there. Galatic also told me before about 2 cubes sealed per 18" but dunno about other sizes. I'm probably going to try one with 6 cubes sealed after displacement for my 3 18's and then about 14 cubes ported with about 300" of port area. Also I've heard that you don't want to tune it as low like you would with a regular ported box.
thank you galactic, and i know that u dont tune as low, i like 27-33 for ported, but yeah i was thinking like 40-45 but 45-50 will be better. thanks
anybody else?
the Answer
DC audio FTMFW
the Answer
sumter county, Fl
RAM_Designs
