4th Order blow through for 10 12s, 87 Chevy long bed
He's got a tri fold tonneau cover already ordered. Made some progress and got a video.
Looks great! Very different for sure.
Maybe I missed it, but yall gona deaden it while the interior is stripped?
Nice build! Cone area build on a budget...nothing wrong with that! Nice to see some quality work going in to pull it all off too.
Thanks!
Looks great! Very different for sure.Maybe I missed it, but yall gona deaden it while the interior is stripped?
Thanks, I think he has some cheap home depot stuff for deadner. The only place that needs it is dash and doors, everything else in interior will be painted.
What kind of numbers you pushing?
Hoping for 152 @ 32hz
Never have cared for the front roll pans on the squares, but that don't matter because it's not my truck. I seen one once that the guy bumped it out like 2 inches, almost like a smooth bumper, it was sick. He also had the roll pan that was even with the tailgate in the rear.
Definitely nice work so far. You should have put a set of comps in the back though since you did the work to cut it out and everything anyway. But nice work regardless.
He said he may go with components later. The 4x10s were $60, a component set is gonna run $150+. This is a budget build for now, he's going to upgrade everything in a few months. We are located in Campbell Texas. We do high end restoration paint jobs and car audio.
Paint going on now will update later.
you may like them facing forward rather than Rear faced. Its all about how you like and enjoy by your ear/listening not others. try Both...
is this a ported enclosure or a 4th order? If 4th and tuned to 33hz, unless specifically designed to do that, it wont have any bandwidth. It might...
I’m going to stick with the 4th order bandpass for now and see if it can improve it. The bandpass actually plays 100 rebased songs good.
I'd try rear facing. Have you tried opening the trunk to see if that restores your bass?
Any direction you orient a sub can affect it's output, this true even more so in a car. Nevertheless it doesn't add an order and generally...
power-fanatic07
Knockin Doors Down
power-fanatic07
Texas
power-fanatic07
