4th order bandpass question
To get the specs of a bandpass, I just use my judgement. Theres no real equation, or calculator or graph I use... I just kinda guestimate. Havent had any problems so far.
Best would be to upload the exact T/S specs of the driver into WinISD and fiddle around with all the volumes and tuning and have overlay the transient response over a typical ported and sealed box for reference. Just **** around with it until you get a transient response that models up nicely and then go about sketching a design that meets those specifications. Let me know if you want any help //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
That's what I've been doing for a little while. What I was trying to ask is if the ported chamber in a 4th order be slightly larger than the recommended box?
Depends on the application and the type of sound you want.
I know that //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
With a sealed box holding air in, I would think the lower end would be extended down to a lower frequency because the sub has more control.
The biggest question for me is what size to make the box.
really has alot to do with the vas of the subwoofer used as well as the Fs and xmax .. typicaly the larger the ported portion the more efficiant the box is but it is also is going to have more of a peak vs the smaller the ported section is the flatter the responce will be over a givin set of freq... if u would like a box designed click the contact button in my sig
For the most part a bigger sealed chamber will drop lower.
Do you just want me to design you something?
Nope. I just need a little guidance.
Just messing around on winisd I have .7 cubes sealed and 1.5 cubes ported, tuned to about 40 hz. Looks fairly good on the graph.
Never tried WinISD, but I know BBP is way off for bandpasses. And 40hz will be a low end monster and most likely wont do much for high bass.
Try 1 cube sealed, 2 cubes ported. Go for around 40in^ of port, tune to 45hz. That would be great for daily for a 12.
i believe the sub he is refering to is a 8"
per 8 i would do .3 sealed into .4 ported 48hz with around 10sq of port that should give u a fairly good bandwidth
winisd doesnt do crap for bandpasses
//content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
I have trouble understand how I can go that big in the sealed portion.
is this a ported enclosure or a 4th order? If 4th and tuned to 33hz, unless specifically designed to do that, it wont have any bandwidth. It might...
I’m going to stick with the 4th order bandpass for now and see if it can improve it. The bandpass actually plays 100 rebased songs good.
I hope you didn’t misInterpret my last message.. I was excited that I actually understand what you’re talking about… Lol! I will level with you. I...
14
you may like them facing forward rather than Rear faced. Its all about how you like and enjoy by your ear/listening not others. try Both...
Buck
little alien on campus
Buck
Inside of a pyramid
AARON30
