4 ohm cvr or 2 ohm cvr? What's the difference? How to wire at 2/4 ohm? Help
What brutus amp?
This. Wiring a couple of 2”VC subs down to one ohm on one of those bigger brz's would not be good. And one nice sub is better than two very mediocre kickers, op. Especially in a car that size.
Wiring configuration. Two dual 2ohm subs can either be wired at 2 ohm or .5 ohm... Two dual 4 subs can be wired at 4 or 1 ohm...
It also lowers the amps efficiency and raises the current draw.
709
What is the impedance of each set of terminals,assuming they represent each of the two dual voice coil subs (4 coils total)? How many sets of +/-...
506
Not all chargers are the same and charge and different rates. Any battery will deplete in that type of weather if you do not crank the vehicle for...
10
Brand new 210 shipped TECHNICAL INFORMATION OPERATION CLASSClass D NUMBER OF CHANNELS01 MAXIMUM POWER@ 12.6 VDC - 1 OHM: 3000W RMS @ 12.6 VDC -...
This is what I usually do before I put my main gear in. For my temp setups, Ill thrown in what I have close by out of my stash.
10
Molinam123
Molinam123
Coconut Creek, FL
Why So Cereal?
Decebal
    Jun 10, 2024
