4 ohm cvr or 2 ohm cvr? What's the difference? How to wire at 2/4 ohm? Help
Something tells me 2 15s won't work in a IS300 if that's your car and CVRs may not be your best choice.
But 2 ohm vs 4 ohm just helps u match up to your amps required impedance for the power u need. What Brutus amp do u have? They are 1 ohm stable so you'll need dual 4s and need to wire them to 1 ohm.
Use this: Rockford Fosgate® - Woofer WiringWizard
Sorry, I didn't see your post but I have everything in the car already and it fits and thanks for the link. But when I'm wiring to 1 ohm do I have to wire it to the terminal on my box or straight to the sub?? Thanks
Wire them to the terminals on the box then run a wire from the pos on the amp to pos on box and same for neg.
Fitting and being done properly are two different things btw. (In response to the box)
Molinam123
Molinam123
Coconut Creek, FL
Why So Cereal?
