I have a kenwwod 1000X1 and a pioneer 300X1 amp. Should i run a 2 or 4 gauge wire to the distibution block. AND THEN run what size wire to what AMP??????
im guessing 2ga tot he dist. block then 4 to the 1000 watt amp and maybe 6 or 8 to the 300....but before we decide that...how many watts do the amplifiers put out and how many amps(current) do the 2 amplifiers draw???
so it only draws 9 amps between the 2 amps.....hmm.....u might not even need that large of wire at all....what are the individual amp and rms wattage of each amplifier?
to the distribution you'r only going to need 4gauge....and untill we get the other info i cant recmoend what size from the dist. block...check out below
