4 Gauge Dual Inputs/Adapters
beatzboi
Im about to pickup a AB PH4000MD, Im noticing it only has 4 guage inputs. I'd like to make sure its pulling everything it can and run 4 gauge to dual 4 gauge input adapters but cant find any? Any one know if they're are even in production. Or would I be better of just doing 4 to dual 0's reducers/adapter
Ok, lemme put it in better perspective. The question I was asking wasnt too precise. My setup (as far as wiring) 0 gauge--distro block (3) 4 gauge terminal outs. RF P400.4, and 4000md are the amps that are currently in. So I want to connect two 4 gauge from distro to 4000md. So would there be any benefit to dual 4s, vs 1 4 gauge? Or should one 2-3 ft run of 4 gauge from distro suffice? This is a 2000 watt amp here so Im just wanting to be sure and safe. I dont really want to have to rerun 0 gauge yet, even though I will be running 2 0's and neg later this summer
just use a 4 awg ofc from the distro for now itll be just fine for that amp. sometimes those distros have 2 1/0 inputs and you can just use the other 1/0 input as a 1/0 output and fuse it to the amp i did that for a while.
With that short of a run from the distrobution block, you're more than fine with one run of 4 gauge OFC
beatzboi
beatzboi
United States
giltyler
