Sold 4 channel kenwood FS
THUNDERBIRD
alrighty i tried to hang out to it for a while but just can't do it any longer. so i am selling my kenwood kac-8401 4 channel amp. it is in great shape a 8 out of 10 has saw dust on it at the moment from my current build it was in the garage for a day when i was cutting. it has a few mismatched screws because they stripped out so i got different ones. had it installed for maybe 2 years. worked perfectly 10 out of 10. so i want $100 shipped, hawaii and alaska $115 shipped didnt sell on ebay and i had it for $120 shipped. they are going for $150 plus shipping on ebay.
BRAND NEW & FACTORY SEALED
KENWOOD KAC-8401
4/3/2 CH 640W AMPLIFIER
NEW 2004 MODEL
SPECIFICATIONS: Cast Aluminum Heat Sink: with Sandblast Finish
Power Indicator: Blue Logo Triangle
POWER RATINGS
Bridged Power Output at 14.4V (1kHz, 0.8% THD): 180 Watts x 2
Maximum Output Power (Bridged): 640 Watts
Power Output at 2 Ohms, at 14.4V (1kHz, 0.8% THD): 90 Watts x 4
Power Output at 4 Ohms, at 14.4V (20Hz-20kHz, 0.08% THD): 60 Watts x 4
AUDIO FEATURES
4, 3, or 2 Channels of Amplification
Ground Isolation Circuit
Input Selector: AB/A (Common)
Quiet Turn-On
RCA Audio Inputs: Gold-Plated
RCA Line Outputs: Gold-Plated
Speaker Connectors: Gold-Plated, Screw-Type
Speaker Level Input Terminals: Plug-Type
Stereo, Left + Right, Mono, or Tri-Mode Operation
Variable High-Pass Electronic Crossover: 50Hz - 200Hz, 12dB per Octave, A and B Channel
Variable Low-Pass Electronic Crossover: 50Hz - 200Hz, 12dB per Octave, A and B Channel
Bass Boost: Off/+6dB (90Hz)
POWER SUPPLY FEATURES
2-Ohm Stable
Copper EE-Core Power Transformer
Noise Supression Filter: Toroidal
Power Input Terminals: Gold-Plated, Large Screw-Type
Power MOSFET Switching Power Supply
Power Supply Fuse: 40A
Secondary Capacitors: 2
THUNDERBIRD
THUNDERBIRD
LANSING, MI
THUNDERBIRD
michigan born
    May 14, 2026
michigan born
    May 14, 2026
