4 Channel into 3 Channel
RI-Matt
I know this is probably a stupid noobie question but here goes.
If you had a 4 channel amp say 100 watts x 4, if you run front speakers off channels 1 & 2 and bridge channels 3 & 4 to run one sub, does the sub get 200w and the fronts still get 100 each???
It will depend on the bridged output on the amp.
Usually bridging two channels into one will give you a single output equal to the two channels' 2 Ohm output combined.
Most Class A/B amps will do 50% or more of their 4 Ohm output when given a 2 Ohm load in stereo.
So, let's say in theory that your amp is rated for 100w X 4 @ 4 Ohms.
If so, then most likely it will do around 150w X 4 @ 2 Ohms stereo.
Your bridged output will then be around 300w when combining 2 channels.
What amp are we talking about specifically?
Thanks for the replies.
The amp is a RF 750x which puts out 93.75w x 4 @ 4ohm, 187.5w x 4 @ 2ohm, and 375w x 2 @ 4ohm bridged.
Thats the advertised RMS power, the birthsheet is 981w total @ 2ohm. So I'm thinking it's about 122w x 4 @ 4 ohm. Sound about right???
Is the sub getting 244w or 490w ????
Matt
yes but your going to want to put a x-over on the wire going to the sub or you'll have a crap load of unwanted frequencies going to that thing
and flakko...isn't that what he said?
wow im out of it....you dont need togain match
but yea i was just confirming what he siad?
RI-Matt
RI-Matt
Rhode Island
flakko
