Hifonics Brutus BX1500D
That amp will do 900 @ 2ohms. The only way you can wire those subs is @ 2.67 ohms. So you will be giving them less 300rms each after box rise.
You could wire it down to .67 ohms, and after rise you will probably sit pretty close to 1 ohm. And those amps I have heard are a little over rated, so you MAY end up close to around 400-450 per sub. A little over rated, but an option.
leeh23
leeh23
Green Bay, WI
bjfish11
