4-channel bridging cause distortion/overheating problems???
PrinceCharming
PrinceCharming
I was wondering if bridging a 4-channel amplifier to 2-channels at 4ohms is going to cause any noticeable distortion or overheating problems. I've been looking at the PPI P900.4 to drive my JBL C608GTI MKII component system. I know it's a little overpowered but I've heard these JBL's can take some serious wattage. Should I get the P900.4 and bridge or should I get a good 2-channel to drive them? The two channel I have been looking at is a Lanzar OPTI700X2 (yes Lanzar is mostly crap but the Optidrive serious is very high quality as far as amps go).
bridging does NOT cause distortion or heating issues when operated normally. by "normally" i mean within mfr ratings.
bridging doubles voltage (which quadruples power). this results in less current which reduces heat and distortion.
That amp does not have the RCA summing feature. You will have to use RCA splitters at the amp. If you already have that, then check the gains.
967
10
487
Slapz are sfb clones from my understanding. What I was pointing out is how much info slapz gives about their amps 😂
35
Thanks for that. Good point about the chimes, I 'll have to check. My thoughts were that a true center channel could serve to raise the sound...
255
It is Opel (Vauxhall) Astra J 2011 model, I change the HU to Kirinavi 10 inch screen. The factory speakers are Infinity and would have come with a...
681
PrinceCharming
PrinceCharming
PrinceCharming
New Albany, MS
akheathen
    May 12, 2024
Brendon Jenness
    May 11, 2024
