Can the Hifonics ZXi 8010 handle 4-ohm loads on the full range channels and 2-ohms on the sub channel at the same time?
New to the forum, just a quick question. thanks!
Have you read the specs booklet yet/or even downloaded the free specs? You can run that amp mixed stereo/mono operation,but i myself did not go into detail as far as ohm load for the sub ch.to be lower than 4ohms
It says the fifth channel can handle 2 ohm loads. (Did I read it wrong?)
My question is if I can run four 4-ohm speakers on the first 4 channels, and two 12" subs (final impedance of those subs together is 2-ohms) all at the same time on that one amplifier?
