4 AB HD Pathfinder Build
What did you end up doing to plug the hole in the firewall?
And use some zip ties ****it!!! //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
Looks loud, good job! //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Oh yea. I got a little square plate to cover the hole, it was made of hardened rubber. i screwed that onto the hole and siliconed around it and the little gaps between each wires. its really messy looking, but its covered. Also I ziptied the wires in the engine too. Just I took the pics before I did that
Nice! //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Okay well my carpet came in.... It defintely wasn't what I expected.. The last carpet i ordered from this ebay seller was the good kind.
The sh!t I just got has that BS plastic backing crap... :/
fock it tho, im still gunna use it.
Pics of carpeted tonight most likely
just out of curiosity, why did you run 3 + and 3 - from front to back, why not just 3 positive to front, and 3 negative to frame underneath? maybe my math is off somewhere i just figured a ground is a ground.
it is a ground, but not a good ground. with an amplifer that will pull as much current as his will, i would want the best ground possible.
It was a total b!tch to work with, but it came out alot better than I thought it would
I also went ahead and flat-blacked the aeros. It looks a ton nicer than I was expecting. I wanted to scream when I saw the carpet
Andrizzle
Andrizzle
Stillwater/Edmond, Oklahoma
Andrizzle
vegang
vegang
