4 8’s in a Tahoe
@Buck you down for viewing a few pics :D
Well I did some measuring. I have 4^ft to work with. That’s with out any displacements, but being that I’m planning on running external ports, all I have to worry about is sub/bracing displacement, but even then, I can make the box a little bigger. I’ve a huge fan of NVX Audio. For the price point, they’re awesome. This is where I need some in put.
2 12” NVX VCW’s (1000w each, going to need a 2200-2500w amp to run at 1ohm)
Or
3 10” NVX VSW’s. (500w each, going to run at 1.33ohm, 2000w amp).
I came down to these two subs, because it’s what I can run. I can get away with 4 8’s, but I’ll be spending much more money.
Being that I listen to a lot of roots reggae (Rebelution, Stick Figure, Tribal Seeds...etc) do you guys think the 10’s would be more ideal since reggae bass tends to be a little all over the place in the bass spectrum? Also they would be more Cone Area, and less total air space, Or just run 2 12’s and call it a day?
I’m currently running 2 12inch NVX VSW v1’s, (discontinued). I could even keep these, but the higher bass notes sound like garbage, which I’m guessing could be due to the box. (Sealed box, same chamber, slightly undersized). Realizing their is a lot I can do now, just trying to figure out what would be more ideal.
I think I’m just overthinking this whole thing idk....
You may need to go to some shows and sound offs/meetings
I would add two more of the same subs and look at selling the 2k to go towards the funds of a decent 5-8k mono amplifier and new enclosure
that was a pain... 2.5 days probably removing everything, cleaning entire area and doing it. ive only done trunk cars before this was def a lot...
14
tallnlow
tallnlow
Santa Maria, CA
tallnlow
    May 12, 2024
Brendon Jenness
    May 11, 2024
