4-4" ports
  • 4
for 11 cubes that is very small...it is only 4.5 square inches of port per cube of box. Most people recommend between 14-17 square inches of port per cube.
thats what i thought. he said the kicker manual has a 3.5 cube box with one 4" port for the subs that he has. that was for one 15". so he was going to use 3 i said to use at least 4 but it still seemed to small. i also have 8" sonotube around. would 2 of the sonotubes work?
10 square inches per cube. but the box is 11cubes? im hoping thats for 3 15s not 2. ill be using a 10" for 8cubes and yeh 2 8" would work good
The late 80's early 90's car's OEM speakers were of the same quality as today's offerings. The main difference was the rear speakers were enclosed...
10
979
You're not trying to figure out the mass of air in your 3" port or whatever, you're trying to figure out the mass of air that you would need in an...
Are you going to do actual aeroports with flares on both ends? I’m running a single 4 inch aeroport on my little 750 watt 12. It has flares on...
The black rca out is your mono sub output. That is the one you would use for signal to your sub amp.
And you failed to mention airspace of the box or the sub and power you were running. In 89 most subs were extremely low xmax meaning very little...
14
energizedsbs
energizedsbs
tarpon springs
energizedsbs
    May 16, 2024
    May 16, 2024
