4 18 Solo X Help Plz give me your .02
RawPower
ok i have a Chevy Surburban and i plan on puttin 4 18 solo x subs in it about 2-3 weeks from now and i wanna know should i get 2 kicker 2500.1 amps for each 18 and plz if you are not going 2 help dont reply i am very serious i have $15,000 to spend on this and i can get all 4 subs for $2000 which means im payin $500 a sub cuz i got connects so plz tell me what is the best route to go and if you know what, where and who makes a 350 to 400 amp alternators i plan on running dual alts and getting about 8 yellow tops 2 50 farad caps and using the rest of the cash for dynamat and wiring??????? Please Please Help
you need cement man, not dynamat
and you dont need 8 batteries, or any caps
you need 4 batteries, if you're doing SPL, you wont be able to drrain 4 batteries in 5 minutes with the car running
you'd probably get better spl with 2 subs than 4, those htings need like 15 cubes a piece.
holy shit your sentences are longer than Hawthorne's
Now do they really need 15cubes each....
And Steve Meade is running 6, 2100CCA batteries for his DAILY set-up which consists of four bd1500's. And why is the cap not needed...
//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
Steve uses 2 1500bd's per MT18(4 of them)
2 KX2500 per sub is a great choice you'll be feeding those subs with at least 6Krms each
I think that you should buy the 8 bateries and the caps... that's a big setup you're goin to be runnin'
Well fuck beans cotton, WAS he usin 4 or am I imagining something else?
Curious.. you planning to remove the back seat (or semi-permanently lay it down) for the enclosure(s)? Those Solo X's need maaaad cabinet volume.
Optima red-Tops "dump" faster than yellows if you need the current. There are other batts out there that better suit a psychotic system like that though. With the right ones, you can cut your count (and weight/space) by almost half. Too rich for my blood though. The quote for my system caused a black-out that only my wife remembers *heh*.
Have you owned any previous systems before? Four 18" Solo X? Do you know how many cubic ft is suggested for just one? I doubt you will have a decent amount of room in a Surburban. 8 batteries? If this is for SPL only you have already started off wrong by your vehicle...you should have a van with 1 seat (drivers) if you want just a baddass SPL setup. Now please do us all a favor and answer this: IS THIS JUST FOR SPL OR DAILY DRIVING TOO?
RawPower
RawPower
Chicago
AndonD454
