cotjones
it doesn't matter if they don't use their full linear excursion because that is only the maximum out putYes, the 13" driver has a higher POTENTIAL linear displacement, I don't think you realize that either setup will almost never use their full linear excursion.
yes if they are both at 10mm of excursion than the 10's will be louder, but to reach 10 mm the 10's will have to use far more power to do it so that means the 13 is louder (see below)Say you give both setups a certain amount of power, that allows them both to reach 10mm of xmax, the 10" setup has more piston area that the 1 13" and since they're both at the same level of excursion at this point surface area is going to dictate which setup will have more output, and since the 10" drivers do they will be louder.
it's not trivial your aren't listening... you are basically saying that all 10's are the same and their excursion capability doesn't effect their whole performance only the maxThe 10" setup will be louder up to a point, I don't understand why you can't see that, basing your entire argument on x is louder than y because it has a higher linear displacement, is trivial at best, you're not seeing that you almost NEVER use a driver's full linear displacement.
exept you don't double the x when going into the 10's... think of it this way you have 2 different functions y=(x)into 2 10'sSince you said X, and I know my math is a little rusty, but generally when X is used as a variable, it's the same in the entire equation, so uhhh if X=500 then 2x=1000, and since we're talking about 1 driver compared to 2, the 2x would be the 10s.
Z=(x)into 1 13
now x is one value of power ... if that value of power is the same in both equasions the 13 will ALLWAYS be louder using the same amount of power
ok so lets say you give the 13 250 and only 200 to each of the tens... but you forget it takes 2 of them to get to the output of the 13, so it's really 400 watts...
i know that at xmax, the 13 moves 277% more air than the 10's which is the ONLY thing i need to know to say "1 13 is louder than 2 10's"You're also assuming that the 13" driver will be more efficient, even with what you listed up there, you don't know anything for certain so you can't say x will be louder than y, because you just don't know.
oh and i don't really give a fvck about the other threads, yeah i said some dumb stuff, yes i have learned alot, now i'm appearantly more knowledgeable than alot of you and the only arguement you have left to hold on to is some of the dumb stuff i've said in the past. get a life because you can't correctly tell me i'm wrong you just attack me
