3000W@1 ohm.... what should I get????
snb778
blaugh!!!!
The catch is...im limited to 7.6cu. ft MAX before any displ.
I'd rather go with like 7 cu. ft to give a TINY wiggle room...
Past Setups: 18" Qw/BP in 5.5cu. ft and 7cu. ft
18" HDC3 in 5.5cu. ft and 7cu. ft.
Looking to get a little louder... after displ. for 2 15's i'd be at about 6cu. ft, which is tight, but is it doable for most 15's??? like 2 15" SE's, or SX's or BL's
if 15's is not a good idea... im probably going to want to do 3 12's or 10's...whatever you guys would recommend
3000W@1 ohm MAX
This is going on the Maxima... can't do a sealed application....
Budget: $4-500
I have seen some RD 3250.1s go for that..... and they are freakin tuff amps. A lot of people are also dumpin the 3000Ds to get the new model. So you might be able to find a deal on those. (same thing.. 3000d, 3250.1)
I think he's looking for sub suggestions.
Omega and HDC3? dont think the 2 are comparable.heard a single 12 in a tahoe off 1500watts, was very impressive.
and hit up ssackett for specs/pics and stuff on the Evos
here's a vid of 15s on 700watts a piece.
http://www.caraudioclassifieds.org/forum/showthread.php?goto=newpost&t=8389
don't think so what??
vid looks pretty nice, but what it does in an SUV don't mean diddly when I put it in my sheet-metal enforced trunk...
I think i'd rather go proper size box/Big port than smaller box, normal port....but 2 15's does have a lot more cone area than 3 10's...thats why im thinkin maybe 3 12's if I can get em into 7cu. before Displ... Not to familiar with the air space most 12's need.. I know 15's like about 4cu. ft after displ.
snb778
blaugh!!!!
snb778
ex. Los Angeles, CA
recluse_tha_rip
