3000 watts for under 500 bucks?
AQ1200D says it pushes 2400@1ohm but really its underrated and pushes right around 3000. $270 x two
(two 2200's would be more ideal, although $200-300 more as well)
SAZ3000/Crescendo 3k's are around $550-650 i believe.
AQ1200D says it pushes 2400@1ohm but really its underrated and pushes right around 3000. $270 x two(two 2200's would be more ideal, although $200-300 more as well)
u have no idea what you.re talking about..aq1200 does not do 2400@1 ohm ..ur looking at max numbers it realistically does around 1500
You couldn't guess that I was talking about two aq1200's linked together, even with the price shown as $270 x two + "two 2200's are more ideal" on next line?? Yes you're right 1500 max realistic max numbers with 1 amp. Quit flaming, begone troll! //content.invisioncic.com/y282845/emoticons/bigwave.gif.16324171cad2db62cf4f16568b038478.gif
Hey ur the one trying to sell ur used amp for.more than aq has them new..he asked for a 3k amp for under 500 not a 1200 and then hes gota find another
Not all chargers are the same and charge and different rates. Any battery will deplete in that type of weather if you do not crank the vehicle for...
10
Thanks man I’ll give it a try I’m usually pretty bad at this kind of stuff. I wasn’t sure if there was a website or something that had a picture I...
But since you guys are still here, I have another question. Now that I have a 3k amp, after I get my new battery and HO Alternator, I'll be in the...
272
20K
adjetta
adjetta
Louisville
pro-rabbit
    May 24, 2024
