3000 rms at 2ohm choice
Cars arent meant to run amps, obv u might have an issue with ur electrical etc. You cannot blame an amp for blowing up. when we cannot see your install. how are the grounds etc, exp when running at .5 ohm.
everyone on here says sundown etc caan run on .5 ohm untill u see all the sundown amps i have seen coming through for repair beause they were ran at .5 ohm. its any amp.
jacob use to sell his saz3k's for like 500 and warrantied them at .5 ohm also. Until her realized its not possible and he stopped. Navid is new to the business young etc, and is trying to build up his company the same way jacob did. He is basically copying jabcob in many ways.
Every one I have played with has been top notch. I just decided this is all I am spending on this car. It will never be what I want it to be. Pay it off, use it as a beater for my 60 mile a day commute and do a SQ build in something nice. Im thinking X5 now but that will change by then.
part of the reason I left the SPL alone in my tC and went with SQ.
anywhooo, a friend of mine just got a 2500cp and I havent sat in it yet but its all he talks about. He says it runs super cool and is easy on his electrical. I forgot how big his alt is though.
Everything was and is fine. The ZX makes just as much power at 2ohms and it only drops to the 12s for a second or two. Same set up just changed amps. 200 HO and 3 yellow tops. 1/0 OFC. clean ground. I guess I could of ran a ground back but Im not.
part of the reason I left the SPL alone in my tC and went with SQ. anywhooo, a friend of mine just got a 2500cp and I havent sat in it yet but its all he talks about. He says it runs super cool and is easy on his electrical. I forgot how big his alt is though.
Its OK loud now for a daily driver. Loud enough. Even if I was to wall it, there is no way to run duals. Batts can only do so much. I wont SQ it though cause the subs have already loosened it up to much. 22000 miles and panels are rattling bad.
i know what you mean. mine was fine for daily but I didnt see it doing anything major in SPL comps. and I just wasnt up to walling it, atleast not yet. You probably have more rattles than me since yours is probably louder than my SA-8s were, and my rattles are killing me as it is so yea unless youre up to some extensive deadening and basically taking entire car apart, dont SQ it lol
you may be able to find an autotek mm40000.1 4000rms at 2 ohm
memphis belle 4k 4k at 2ohm
US Amps USA-3000 3000 Watt Amplifier | eBay
really nice amp ut may need 2 much electrical
450amp fuse for that US amps? is that to use it "cheater" load? I want a MOJO 4K. I could do it and DMM set it after the scope. I just know myself, if I have the power i want to use it.
Its really good in the MECA park and pound stuff. Its only a 1.5db behind the guy that won state and finshed high in the finals last season. If I could get some TL time I might could match him. My sunroof track is bent also
LosIsATool
LosIsATool
Pensacola, Florida
Why So Cereal?
