3 way placement
  • 4
bigaudiofanatic
Dynamic Mobile Audio
1,961
Dover DE
So I will be getting a set of cdt 3 ways soon and want to start installing asap.
I own a 03 civic coupe that has factory locations for the 6.5 and the tweeter. The tweeter locations are about 4 degrees off from being on axis and they cross about in the middle of the car.
My questions are should I use the factory locations for the tweeters? Or should I place them somewhere else?
Also I am planning on doing something like these kick panels but without the tweeters there.
Midrange Kickpanels Fabrication *WORKLOG* - 8th Generation Honda Civic Forum
Would this be good or should I add the tweeters there as well?
Thanks in advanced.
Here is my factory tweeter locations. You can see them on the doors. I can get better pictures if needed.
get you some velcro for temp mounting, and try the tweeters in both locations and see. Tweets in the kicks in that car have been doen with success, as have tweets in the sail panels. JUst a matter of your personal taste. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Trying the tweets in different locations is a suggestion. What sounds good to me in my car may sound like ass to you and vice versa. Two identical make, model, and year of a car can be acoustically different inside. I suggested an easy temp mounting method to find what sounds best to you. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
that is an Ideal crossover and designed for use in an home type loudspeaker. A simple Linkwitz-riley 2-way is easy enough/ The tweeter wire lead...
36
Yes, time to move some stuff for sure. Have a little mini CA warehouse in the garage!
10
670
If not the kick panel, then I'd go dash Generally the farther away the better
Thank you. I’ll make pods for the doors. Next question, My back doors have no speakers. The rears are in the rear pillars. My front doors have 2...
bigaudiofanatic
bigaudiofanatic
Dover DE
keep_hope_alive
    Apr 27, 2024
audiobaun
    Apr 27, 2024
