3 ohm
You have the option of 1.5 or 6. If you run it in parallel for 1.5 after impedance rise created by the box it will likely be around 1.9-2.1
What he said........................there are TWO ways to wire dual coils.
It also lowers the amps efficiency and raises the current draw.
613
What is the impedance of each set of terminals,assuming they represent each of the two dual voice coil subs (4 coils total)? How many sets of +/-...
416
Not all chargers are the same and charge and different rates. Any battery will deplete in that type of weather if you do not crank the vehicle for...
10
Brand new 210 shipped TECHNICAL INFORMATION OPERATION CLASSClass D NUMBER OF CHANNELS01 MAXIMUM POWER@ 12.6 VDC - 1 OHM: 3000W RMS @ 12.6 VDC -...
This is what I usually do before I put my main gear in. For my temp setups, Ill thrown in what I have close by out of my stash.
10
Liquid Bass
Midwest Militia
Liquid Bass
KC Missouri
DBBOOM
    May 31, 2024
    May 24, 2024
