hispls 5,000+ posts
They're selling the same boards as Twisted but pretty much at a break-even or loss.i literally dont get what the hard on is with this wolfram sh*t
Won't happen...no matter how many times he says it will. Someone who says it's easy to get that high of a number and has never done it before is easy to say than actually trying to do it. 2 diff things.You'll never make it to 160 with that attitude.
easier than 1 ohm too but...............Wanted to add also that running 2k @ 2 ohms might be more efficient/easier on electrical than .5 ohm with less efficiency. Someone can chime in and see if I'm right.
You not going to get a .5 ohm reactive load unless you use Dual 1s and are quite a bit away from Tuning.You'll never make it to 160 with that attitude.
You guys need to get together and put your money up it's an easy win I'm going to hit 160 regardless even if I gotta buy two amps if my impedance is highWon't happen...no matter how many times he says it will. Someone who says it's easy to get that high of a number and has never done it before is easy to say than actually trying to do it. 2 diff things.
I demand you rename your screen name to mr. 2 ohmeasier than 1 ohm too but...............
I don't really partaking what other companies charge and where they get their stuff but let's just say that 599 as a fair priceThey're selling the same boards as Twisted but pretty much at a break-even or loss.
2ohm mafia maybe.. but i'll be at 1 ohm if i can sell some of what i got or find a killer deal one 1 of the 4-6 subs i may want to try in my box..I demand you rename your screen name to mr. 2 ohm
Very much more efficient and easier on all equipment. And marginally better sound.Wanted to add also that running 2k @ 2 ohms might be more efficient/easier on electrical than .5 ohm with less efficiency. Someone can chime in and see if I'm right.
If you plan to get to 160 with a 7K amp you had better be thinking about that.You not going to get a .5 ohm reactive load unless you use Dual 1s and are quite a bit away from Tuning.Trick is to tune about 2 or 3 hurts under resonance and then go from there you know this already though
Mr 2ohm son!!2ohm mafia maybe.. but i'll be at 1 ohm if i can sell some of what i got or find a killer deal one 1 of the 4-6 subs i may want to try in my box..
How is it throwing it away? You know I'm an idiot..I work too hard for my $$ to throw it away...esp at some stupid bet.
