2nd battery volatage??????????
jcadams
I have a normal car battery up front and a optima deep cycle battery in the trunk i have a 135 amp alternator in my civic. the back battery is wired parellel i think where its 1/0 wire from positive to positive and then the nagatives are just grounded to the chassis. The battery in the trunk is used to power compresors and valves for air suspension and in the future a sound system
i am getting ready to install amps to this battery, but first i threw a volt meter on it to see wat i was reading and i got 23 volts so i tried the front and had the same 23 volts. i am worried about burning amps up with this kind of power i thought i should only be reading 12 or so volts not 23. my 12 volt compresor is running fine of this power source and nothing seems to be running differently i am just worried to hook two brand new amps to something that could blow them up.
Any help would be greatly appreciated because the sooner i find this out then sooner i put my system in thanks
yeah that wat I thought would happen with all my fuses if I really wad running 23. It could be the meter I was using it was like digi with a turn dial for different settings. And I'm sure it is wired right positive to positive and then the ground is put about five inches away in chassis both batteries
if its a true 23 volts my guess would be a bad voltage regulator.. and most automotive fuses are 25volt or 50 volt fuses fyi. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
yeah it goes positive of my front battery with 1/0 wire to the positive side of my second battery. the ground of the front battery is about 3 inches away with 1/0 to the strut tower. the ground of the second battery with 1/0 is wired through the bottom of the trunk with a bolt throughfrom and the ground
have you tried getting a reading from the battery in the front without the other one connected?
try that and if it still reads wrong then its probably the voltmeter
jcadams
jcadams
peoria il
DBBOOM
